1 - 20 of 33 Posts
just wondering if someone could post a couple time slips from a 5.50 pass so i could see what i would have to do to get into mid 5s and possible hp #s as well thanks, mike
This is about 375hp, 64" street tire no bar. ZRX1100 blow thru turbo. -Dean
hey thanks for the posting the 550 run is where i was thinking if being next year but i was hoping to get there with only 225 250 hp :dontknow: (dont want to put crazy boost to it) how much do you and bike weigh??
About 710lbs. This was a Super Street bike, with 3" ground clearance and a Shinko, 2 stages of boost, 2 stage clutch.
If you can get low and long enough, you can run 5.50s at that power with a multistage clutch and a shootout tire. Why not just spray it if that's all the boost you're going to run?
Dean
i probably should just spray i have a couple of wet kits already it sure would be alot cheaper !! thanks ,mike
buy a busa with a turbo. your going to spend a ton to try to do that on a 10. there is only a handful of high 7 to low 8 second 10s and most of them wont admit it.
the best i've gotten on mine is a 6.0 1/8 and a 9.18 @160 on mine. i've got an 06 stretched 9' lowered, down 1 up 5, muzzy m-10, pc, ignition module, block offs, tre, and a 40 shot. i'm planning on racing cams 50 mm head gasket, port and polished head, and 3 angle val job. so hopefully i'll get in to the 5.6's and 8.8's next season
Thats good MPH:thumbsup: how much do you weigh?
Discussion Starter #15
thanks guys for all the feed back im just going to pipe pc race cams and head gasket for now maybe lower and longer too. hope to see if i can run cosistant 5.7 5.8 also i was thinking about ceramic wheel brgs and cut oil pan. not sure about those though
definetly cut the oil pan. you will probably end up breaking it if you dont. I went 9.0 on my bike with just head and cams.(And I cant ride that well):thumbsup:
MIdlife PIMP
what do you guys mean by cut the oil pan?..........just curious!...Russ
1 - 20 of 33 Posts
