1 - 12 of 12 Posts
I've tried a few times to stoppie my 2013 ABS bike but I'm not having any success at all. High angle, rolling stoppies used to be my thing when I rode 10 years ago but I took a decade long brake from motorcycles and now that I'm back I just can't seem to stoppie this, my first ABS bike.
After gently preloading the front end I can feel the brake bite hard but then the ABS chatter engages at the slower speeds just before coming to a stop. Maybe I just need to grow some balls and try it at higher speeds? I'm trying to get back into it with baby steps. I.e. I just want to lift the back end an inch at first and build progressively to the big stopppies.
Thanks
Thanks
Pull the ABS fuse, maybe?
Uh.....so let me see if I understand this correctly. You bought an ABS-equipped bike to prevent the wheels from locking up and preventing stoppies. Yet, you're trying to do stoppies on an ABS-equipped bike. :idea: Yeah, keep trying that. :spit:
No, the WHOLE purpose of ABS is to stop you faster with BOTH tires on the ground. Ain't happening unless you disable the ABS system. :headshake:
I was going to ask the same thing, but then I thought, maybe he's trying to see if he can overcome the ABS???
Thanks for the suggestion Ninja. I commute on my bike so I'll just leave the fuse in. Maybe if I do a track day.
Let me explain it in another way. I can pop a fairly high wheelie in TC setting 1 before the TC system begins to detect differences in wheel speeds and the power is curtailed and the front end comes back down. I'm exploring the ABS system in the same way. I want to see if I can pop up the rear wheel at speed while both wheels are rotating and see how the system behaves at various levels of braking and speed. I actually never lock up my front brake when performing a rolling stoppie. I always let off just before I come to a stop and roll away again without putting a foot down. Hence why I describe it as a rolling stoppie vs. an endo.
Btw your reply was quite harsh. Rather insulting and unwarranted I must say.
Nope, it was all in good fun to a answer a rather obvious question.
ABS is designed to stop the bike in control and in the shortest possible distance. Therefore, both tires will remain on the ground at all times to accomplish this. Allowing the system to lift the rear and make it dance around on the pavement is not in control. The ABS algorithms prevent exactly what you're trying to do. It's not like traction control where the bike will keep going forward with the front end in the air slightly. It's ABS and it wouldn't be a very good system if you could do what you're attempting to do.
If you want to do stoppies, turn it off.
Ahh I see the situation much more clearly now. Thanks! The "aha" moment is when you explained that allowing the back end to come up would not be a system that is providing more control. That makes a lot of sense. What confuses me is that in all my testing of the ABS I can feel chatter at lower speeds just before lock up but I never feel any chatter when applying hard braking at higher speeds. Maybe I'm not using enough brake at high speed to even activate ABS or the chatter isn't noticeable at that speed.
Regardless, I won't bother trying to stoppie the bike anymore.
cheers
cheers
The ABS does not function below 5 kph (3.1 mph). You may be feeling this as you come to a complete stop and the system turns off. And I doubt you're feeling chatter (which is the tire skidding on the road), and more of the ABS cycling (pressure applied and removed to the disk brakes). :dontknow:
Yes that's correct. When I refer to chatter I'm speaking of the electronic brake pulsing and not tire skidding.
You might be interested in reading this.
http://www.moto123.com/motorcycle-news/article,kawasaki-s-ktrc-kibs-explained.spy?artid=134122&pg=2
KIBS was design to improve the ABS functionality even with fade, and the Kawi engineers have put a lot of effor into keeping you from feeling any pulsing. That being said, I have had my ABS come on and felt a pulse in the rear brakes in the rain.
lol
Ive tried to get the abs system on my bike to engage at any speed without success, and ive tried hard. So maybe its performing without any tell tale signs.
On another note wheelies with tc on is very easy. Setting tc1 ive had the front wheel up in 1st, and 2nd til about 110 mph then it will let itself back down rather nicely even with the throttle wide open.
After flashing my ecu it will wheelie 1st, 2nd, 3rd, and come up top of 4th very easily depending on my seating positions.
1 - 12 of 12 Posts
