1 - 5 of 5 Posts
FTD Extensions, Bazzaz ZFi, SC Slip-on w/mid pipe, Lowered, and much more!
looking for 4 short velocity stacks thanks
I know this is like a million years too late (because I just got my ZX10R and joined this forum in 2021 lol), but if you go to www.kawasakipartshouse.com you can buy the factory short velocity stacks for like $10. They will bolt right into the middle two ports. Supposedly gives you a little more top-end power, at the loss of some low and mid-range power. Hope this helps.
Map Font Parallel Rectangle Auto part
Font Screenshot Material property Parallel Rectangle
I just ordered a spair eBay air box took the two short stacks out and swapped em with the tall stacks on the bike I got the air box cheaper than I could get the stacks
It does not make power just moves it farther up the torque curve
How do you fit tall stacks on the outside for cylinders 1 and 4? The air box isn't tall enough in that area.... Interesting.
1 - 5 of 5 Posts
