1 - 11 of 11 Posts
Hello everybody.
I need a size of 2011 and up zx10rs throttle body,for my own supercharged project.If someone can help me,please send me this sizes,thank you.
I can probably go grab some measurements for you next time I'm out in the garage but it might not be tonight but will be sometime this week.
Discussion Starter #8
Thank you,man!I cant believe,i am so lucky..okay for sure...48mm internal bore-wall thickness-distance to next wall-wall thickness-48mm internal bore,right?And this 32mm(-wall thickness-distance to next wall-wall thickness-)
If so,i must search a cheap one to buy :)
Discussion Starter #11
I dont think so.You can make aluminum maniford with hand,or carbonfiber,or welding,or use the original gum stacks with aluminum panel..there a lot of way,if you know what you need. :)
1 - 11 of 11 Posts
