1 - 15 of 15 Posts
Has anybody used or know of any other than Kawi's race set and Carpenters? Ive already checked with APE and Kibble White with no luck.
Did you find what the difference is in the intakes? I dont have the stockers here to check right now. I see that the tappets are the same part number for ex and int so I assume that the diameter is the same.
Discussion Starter #13
Got ahold of KW today, they do not have a package specificaly for the 08-10. What I got was the specs for the 06-07 package so I can compare with mine and hopefully be able to run then just as 09zx10miami is doing. Just waiting on my builder to get me the stock specs and I should be good to go. In mean time I decided to send my primary injectors off to be modified in preparation for E85.
1 - 15 of 15 Posts
