1 - 7 of 7 Posts
Does anyone know what harness I will need to run the kit race ecu and keep all my electronics working....Such as tailights and headlights? Being that its going on a street ridden bike and not a track bike....
Banned
Kawi makes a wiring harnes adapter so the Kit ECU plugs into the street bike harness and the good part is, its not hideously expensive.
The part # is 26031-0700. Google the part #, you will find out all you need to know.
Congrats on purchasing Tenn10's parts. What a deal!
Banned
You can also read about it here; page #10 of 61
http://www.kawasaki.com/Content/pdfs/brochures/09PerfParts.pdf
2 Electronics Group - Ninja® ZX™-10R (08)
Ignition
Adjust or control the following functions: Fuel Injection, ratio of primary vs.
secondary injectors, Ignition timing, secondary throttle butterfly, engine
over-rev, auto-shifter ignition cut time, pit road speed limiter, rev spike
control sensitivity, rev spike control ignition cut, launch control • Subharness
(26031-0700) is required when using the stock main harness
and is not required when using the racing main harness (26031-0698
or 26031-0699) • PC interface connection (26031-0025, serial port
only) does not mount to the vehicle, but is a required "tool" in order to
communicate with the Adjustable ECU
Ref. No. Part Number Description (QTY) MSRP
21175 21175-0212 Adjustable ECU $617.95
26031 26031-0025 PC to ECU interface $601.95
26031C 26031-0700 Sub harness $113.95
N/A R0045Q-10 Racing Spark Plug $110.00
N/A R0373A-10 Racing Spark Plug $64.00
1 - 7 of 7 Posts
