1 - 7 of 7 Posts
The stock flow of the primaries is right about 310cc and the secondaries are 210cc.
How do I know if my injector is low impedance or high impedance?
You can measure the resistance across the two terminals of the injector and if it is between 1.5 and 4.0 Ohm, you have a low impedance injector and if the range is between 10 and 16 Ohm you have a high impedance injector.
I got the above off of FIC's website. I am headed to the shop right now, I will check one of mine for ya while I'm there.
I'm just gonna send them here...
http://proflowtech.com/index.html
ive got someone a little closer that I grew up with.....Just trying to find out a little more info about the injectors before I decide what direction im going with the fuel system....And if anyone want to build 3500hp+ engine, they should try these badd boy injectors out...:mrgreen:
1 - 7 of 7 Posts
