2019 ZX10RR head mods
806 Views 10 Replies 4 Participants Last post by  teambearsouth_56
Hi all, got a green light to dive into the engine & squeeze more power. As of this time the head is halfway done with porting, intake ports require some filling to remove the low spots to blend in. On the 17-18 ZX10RR only the intakes were ported but on the 19 ZX10RR the exhaust is also ported, the guy that did this head must be in a hurry to do the intake as the finish isn't consistent from port to port.
Tire Motor vehicle Green Automotive tire Wheel
Motor vehicle Automotive tire Automotive design Engineering Gas
Automotive tire Motor vehicle Automotive lighting Automotive design Vehicle
Motor vehicle Automotive tire Automotive exterior Engineering Gas
Gas Automotive exterior Automotive wheel system Metal Font
Hood Red Automotive lighting Rectangle Motor vehicle
Automotive design Automotive tire Motor vehicle Engineering Automotive exterior
Hood Motor vehicle Gas Auto part Automotive exterior
Artifact Automotive tire Snout Auto part Automotive wheel system
Hood Automotive tire Motor vehicle Vehicle Automotive engine gasket
1 - 11 of 11 Posts
Appreciate the photos.
Have you seen what a Gen3 looks like? Does it need any kind of stage 1 TLC such as this?
Honestly I haven't come across any Gen3 or older cylinder head, I think any cylinder head would benefit from getting this treatment.
  • Helpful
Reactions: 1
dirt carbon on the pistons, you gonna polish the piston tops or new race pistons
  • Like
Reactions: 1
Are you referring to me? No new pistons, just clean them up.
Automotive tire Automotive engine gasket Gas Auto part Motor vehicle
Automotive tire Motor vehicle Automotive engine gasket Automotive exterior Gas
  • Wow
Reactions: 1
Sorry for being lazy, but what's under here?
Automotive tire Bumper Wood Fixture Automotive exterior
The service manual says the “Torque Limiter” is under there. Not 100% sure what that is (slipper clutch?) but make sure you seal the cover properly if you remove it. Otherwise it will leak oil. AMHIK
  • Like
Reactions: 1
Basically the starter mechanism.
  • Like
Reactions: 1
Let's get this project going.
Done porting the intake & exhaust, milled the head surface.
Assembled the valve train & checking squish clearance.
Audio equipment Gas Electrical wiring Electronic component Machine
Audio equipment Guitar Engineering Machine Gas
Motor vehicle Automotive tire Hood Vehicle Automotive engine gasket
Motor vehicle Automotive tire Automotive engine gasket Engineering Vehicle
Motor vehicle Audio equipment Gas Engineering Machine
  • Like
Reactions: 1
Even with the thinnest kit head gasket for this engine (0.65mm) there's plenty of clearance between the head & pistons, if there was a 0.60 or 0.55mm kit head gasket I would have fitted it to get more compression out of this engine. Anyway I'm setting the valve clearances now to kit manual specs & I ran out of shims to adjust it, waiting for Kawasaki to ship out the shims I ordered.
Gas Engineering Machine Auto part Art
Font Wood Publication Paper Pattern
order shims for amazon or ebay ,all balls racing shims are fine
  • Like
Reactions: 1
1 - 11 of 11 Posts
