1 - 6 of 6 Posts
Alright, long story short. Im in the middle of the first valve clearance inspection, quickly realized that Gen5 manual is NOT accurate for the 2019 with finger followers.
I found the correct spec (AFTER I already ordered a TON of shims), turns out only like 4 are out. No biggie.
Got everything put back together and have a lot of valvetrain noise now. Verified that the timing marks are all aligned (1 / crankcase union, intake and exhaust aligned to timing cover / valve cover deck). Double checked the clearances, all within spec (Intake Intake: 0.12-0.16mm , Exhaust: 0.14-0.18mm).
Only thing I can note at this time is the CCT gasket was not replaced during the repair (its ordered). Its a very small leak, and I doubt its the cause, but feel it should be noted.
Bike has 15.8k miles.
Anyone have any ideas?
16k miles, is it the OEM CCT? You might look at replacing the spring in it.
I had my gen 5 refreshed and the builder put the shims on the right side of the spec. I feel like maybe it was a little louder/sounded different from before (they were on the big end of the spec) but I haven’t felt anything super weird and haven’t noticed much besides it sounding a little different.
unless I can find some conflicting info I guess the kawi’s have always had generally noisy valve trains.
Discussion Starter · #4 ·
I did reach out to Kawasaki and got basically told to pound sand, buy our service manuals. That lead to a nice argument because there wasnt a manual listed. After some time they found the manual for the ZX1002E (If anyone's interested, its under 2021-2022 Models).
Ill update after I get the book and make sure the specs are actually accurate.
This type of valve system makes noise. There's nowhere in the manual tat says it should be quiet. Open up the hood on a Toyota car and you'll hear the same noise.
My 2018 ZX-10R with 3K miles on it is also noisy and it worried me. I showed it to a mechanic and he said it is normal. My bike runs hot in the city but on the highway, It is normal in hot weather.
1 - 6 of 6 Posts
