To further clarify the difference in this car setup, we had to go for more mid range since many of the other components already improved top end so much. With these cams we would have had to rev to 16k or higher to even see a peak power. When we ended the pull at 14.7k, that was peak power (about 234ish) and still climbing. Our graph looked very different to the one above with both these cams and Kit. Our airbox is top feed and 2-3x the volume with a filter 2-3x the surface area and our exhaust is significantly bigger and breaths significantly better. This cost some low and mid range but dramatically improved top end breathing. This required some creativity in other places to re shift the power band back down and buy back what we lost. We now peak at around 14.6k with 95-96lbs torque. Revving to just over 15k with no drop off and more then 234ish
to my understanding, these are the best cams going for road race bikes. Had we stuck with them, we would have changed other things back and the customer would have been plenty happy, but this was a pull out all the stops program.
