Hey All. Having some trouble with my 2018 zx10rr. I was having an issue with a pcv working properly without throwing codes and it was not happening so I removed the pcv and now I am getting a check engine light that is saying “air intake solenoid malfuntion. Open circuit or short”. I’m going to take off the tank and make sure all wires and hoses are connected properly. Current modifications are:
-smog block off plates
- servo buddy
- akra slip on and mid pipe
I’m 99% sure we did not remove the ais since I have not flashed the ecu but it is not engaging the flaps. Looking for any other ideas before going under the air box.
Thank you in advance
- servo buddy
