1 - 3 of 3 Posts
I am working on 2018 zx10r with abs. i have gone through the whole bike and i am not sure why it would not spark.
so far
i have replaced
crank position sensor
ecu
most of the relays.
clutch lever sensor (bypassed and replaced)
kickstand sensor (by passed and replaced )
by passed the
ignition switch
the bike crank. fuel pump comes on. no spark.
the odd stuff happening
1- the emission sensors (on the left fairing) and the one connecting the smog under the tank are getting hot with just ignition on.
2-i got the bike to spark couple times by putting the bike in gear and pushing down on the quickshifter . i also tired with quickshifter disconnected , and replaced the quickshifter and no change.
Dont forget to Pull your ignition coils and test them with multi meter as well my r6 had bad coils a few years back and i spent entirely way to much money and head scratching for it only to turn out to be bad coils
The Pace
Salvage bike? Meaning, did the bike run when you bought it? let the tech guys know everything as you showed your hand by going through a 2018 10r.
1 - 3 of 3 Posts
