7k on the tach is the sweet spot for the power curve for lofting it. If the KTRC is truly turned off on the bike, a rapid throttle close/open will stand it up in the first 2 gears at 7k.
If you're only able to clutch it up a foot, then you're not high enough into the power band, your clutch is slipping, or you haven't actually turned off the TC. Weighing down the rear more with the ass movement makes it easier, but not needed. Just give it more gas!
Gearing is another way to go if you wanna showboat.
