Noticed an issue over the last few hundred miles, essentially 3/4 WOT or up trying to shift from 1st to 2nd gear using the QS for whatever reason between 6k-8k RPM the shifter won't move at all. Imagine trying to shift up from 6th gear (like it won't budge) if i continue to hold the throttle open pass this point and don't roll off once it hits 10k it will shift with no issues at all. And if i just hold off shifting earlier and shift after 9K-ish RPM it will shift no issues.
Bike hasn't been tuned and has a 3/4 arrow system on. I've tried moving the shifter around height wise but the issue is still there...any thoughts???
