Hello guys, I recently put a PCV on my 2016 ZX10R, and after the installation the FI and CEL came on. I pull out the codes and got code 41 42 43 and 44, which are fuel injector 1 2 3 4 are mulfuntioning. The bike starts and runs just fine. I rechecked the connectors on the injectors and they are fine. Put everything back in, start it up and run it, still got same codes. I went to the dealer and had the codes cleared, but same things happened after a short distance of traveling. I even tried manually reset codes (from the owner’s manual), but it did not work. Any ideas? Thanks.
