2016 zx10 mapping
1171 Views 6 Replies 4 Participants Last post by  Hiddenheat9mm
I have a 16 zx10 w/ 2 brother slip on, k&n race filter and block off plates. Using power commander 5 map but I think it's off. Anyone have a map? I have engine clunky noise around 30mph, check engine light on and 3-5 backfires every downshift 2nd to first to stop at a light
1 - 7 of 7 Posts
Welcome to the party!
A map for a PC5? Those things are ancient and with the reflashing these days, no one really uses them anymore. If you're not going to tune it to match your bike, or start to fiddle with the values in the map you are using to make it better, then find something else off their website and try it. And keep trying that until you get sick of the crap out there and do it the right way! :ayyy:
And that "check engine" light should be the first thing you address! No PC5 map is going to fix that!
  • Like
Reactions: 1
I just added all that upgrades so I wanted to start with their map. That isn't where I'm staying. I'll have it on a dyno this week and sending ecu off to get tuned next week. Just needed opinions on what's going on possibly. Thanks anyways brother.
Spoke to a buddy and he said check engine light is most likely servo and I'll need a flash. Next on list I guess.
He's right you know.
If you completely removed the servo motor when taking out the cables, then yes it'll pop a light in your dash.
The check engine light is the secondary FI pump. When you add block off plates ecu keeps looking for the valve. Oh well. Getting flashed this week anyways:) BUT.... did find out that there's a recall on 2016zx10 with certain vin for the pos can chain tensioner. Getting that swapped out as well
1 - 7 of 7 Posts
