1 - 16 of 16 Posts
Hi guys,
Going to buy a 2014 zx10r in the next week, just curious about wheelie control and TC.
Can someone explain to me exactly how the wheelie control works? I've had my wheelie days and not keen on losing my license again, it's been 9yrs since i had any fines. Don't get me wrong, i ride my bikes fairly hard but just prefer redlining and twistys over wheelies.
Say if you pin it in 1st gear from down low, wht rpm's does the front end lift up at? and will the wheelie control stop it seeing the skye and bring it down gently or have i heard wrong? Also can you pin 2nd gear to redline without the front coming up if you are leaning right over the tank?I'm guessing the higher the TC setting the more it cuts in on the wheelies? Or i could be wrong..I'm asking this because im coming from 10 yrs of riding 600's, and they don't power wheelie without a bit of help with WOT jerk.
Cheers
The only wheelie control I know of is in your wrist, From my experience so far with the Gen 4 is that it will not power wheelie in any of the 3 levels of TC. I've had it in level 1 and it kicks in as soon as you snap the throttle back. For me to power wheelie this bike I have to take TC off, also I have -2 front.
Formerly "bms"
Hi guys,
Cheers
https://www.youtube.com/watch?v=TsTf3HLCGl4
Example of wheelie control maybe? Can't really tell.
Oh, they wheelie...
1st gear TC on 1 Power on max ~80kph
2nd gear TC on 1 Power on max ~130kph
4th gear TC on 1 power on max ~240kph
Wheelie and TC is determined by comparison between front and rear wheel sensors....
As the front wheel lifts its starts to slow down, the bike detects it and tries to slow the rear to bring it back down. Enough throttle, and inertia will overcome TC, and it is possible to flip one if you put in the effort.
Haha, thanks for the input.
Im sure its not going to flip in mode 1 judging by the mechanics behind it...maybe if you yank it up and double jerk the throttle enough..
But under normal throttle pinning conditions with decent throttle control it shouldn't flip even on full power i assume..i've recently seen some guys on youtube pinning it in all gears at high revs and seems like it will get 20-30 degrees or so then start to come down. If it didnt the TC would not get half as much praise as it does i guess.
Oh well, its not like im going to be doing anything silly or trying to make it see 12 oclock.
Thanks for the info guys :)
The G4 does not have wheelie control. Period. The TC system works by measuring the difference in front/rear wheel speeds. If you can get the front up fast enough where the front wheel doesn't slow down enough compared to the rear wheel, you can flip the bike over without intervention from the TC. In practice, the TC will limit the front coming up because the front wheel will usually slow down soon enough.
But you must remember this while riding it. There is no launch control or wheelie control specific to this system other than how much you open the throttle with your wrist.
Thanks for the reply, yeah i understand its not actually designed as wheelie control, but the front wheel moving slower being off the ground will trigger it etc.
I'm curious tho, in what situation would u be where the front wheel wouldnt slow down once lifted from the ground, it makes sense that it would slow down 90% of the time.
Here's the short clip i was watching, im sure you can try open the throttle much more violently, but under normal circumstances and giving it some gas it seems like it works quite well
https://www.youtube.com/watch?v=bnSsFUomCyE
Yeah, that's not really a good test showing it. All he's doing is opening and closing the throttle rapidly. There are instances, especially in the low gears, and especially if the bike is re-geared lower where it's possible to get the front up quicker than it will slow down from being in the air. Mis-shifting with the clutch is another example. Too much throttle with an abrupt clutch engage can do it too.
The biggest thing about this system (as turboR1 already stated above) is the system is not designed for that function. Therefore, it is unreliable while preventing it. No two wheelies will be the same. Sometimes the conditions will allow the front to come up real high, and others will barely get it off the ground because of the TC. So just make sure you know that it can and usually will help, but shouldn't be relied upon to save you from looping it each and every time.
Thanks SD, good information.
As you said i would never rely on it fully, it's just nice to know you wont loop it unless you're being silly in 1st gear or clutch it with a shitload of rpm's accidentally during a change/miss-change.
On most litre bikes i've ridden i usually shift out of 1st at around 10k with a decently controlled roll on, and even if it gets the front a little up in 2nd WOT it wont flip on me as long as im tucked over the tank.
These things really can bite you a bit harder than the 600's can't they :smile:
Discussion Starter #11
10k rpm? You're missing all the fun.
Well i wouldnt say all the time, but then again i've only ridden 3 litre bikes, been on the cbr600rr for years, also had a gsxr750 for 6 months while a friend was away.
I'll be sure to ring out 1st gear on the zx10 when i pick her up next week.
This bike really fights the wheelie when on the tank.
At 180lbs without gear, I cannot keep the front down by using BP alone. The reason why you think it does is because of the TC engaging caused by the front wheel being off the ground.
At 260lbs I can't get the front wheel up with TC on. My poor bike
1 - 16 of 16 Posts
