1 - 4 of 4 Posts
Anyone have this issue. I have Akrapovic Slip-on with mid pipe, PCV, ASV shorty levers, and K&N Air filter.
Every now and then the engine will cut out and run on what seems to be 3 cylinders. Sounds like and RC51. Then all of a sudden it will snap back to normal.
What is it?
Also I can only start it in Neutral after the installation of the ASV levers.
What Archer said.
Clutch safety switch isn't getting released properly cause you've got your ASV levers set too close to the bar.
1 - 4 of 4 Posts
