Frame: $1300 plus shipping from LA. Parting out my 2011, frame has some light wear marks, and the steering stop lug is broken out. All else is in good shape.
No title, bill of sale only.
Subframe: $150 left and right rails and tail
Triple: $200 complete all pieces, the top triple has the surround piece around the ignition broken out
Swingarm: $60
Gen 3 front wheel with rotors: $300 direct fit into gen4 forks, includes tone ring
Gen 1 rear wheel: $120 direct fit into rear, use the gen 4 caliper bracket. includes cush drive, axle and spacers, rotor and tone ring
forks with Ohlins inserts: $1000, should get a refresh for optimum performance, 1.0 springs installed, 0.90 springs loose included
gas tank: $150, holds gas and the mounting bolt holes are in good shape. The corners are dented in, and the right side has a crack that is repaired with 2 part epoxy called steel weld. Includes a twist of gas cap.
Swingarm: $60
