1 - 12 of 12 Posts
Discussion Starter · #4 ·
A lot :lol: from the bottom up lightened balanced edged crank, balanced rods, big bore 79mm Wossner pistons, 0.018 cometic gasket, 0.3 head skim, +1mm valves, velocity ported intake, Gen4 kit exhaust cam, a Kent inlet cam reworked Gen3 KIT cam, K&N race filter, Acropovic headers & a 64mm Arrow end can, wollich flash & re-map. Im going to do something with the stacks & airbox next.
nice mine made 190 last time at the dyno trying to add a few more things to try to put it at or over 200
Great results Michael...Maybe its MR12 time now...I think u could see 210-213 for sure...
How much did u light up the crankshaft?
Got any on board video from dyno like this?
Discussion Starter · #9 ·
I don't want race fuel it's so expensive although it would be interesting too see what happens. No video I should have done I know, 900grams of the crank it spins so much better much much better, well worth it if your splitting the case anyway.
Discussion Starter · #10 ·
Good power that. Id be a bit worried about reliability with high compression. Do you know what the compression is? I skim heads at work but .3 is alot to take off
It's running fine no heat issues so far, rod stretch Kawasaki say 0.06mm Iv got all clearances down to minimums, checked the old fashioned way using clay, it's been smashed off the limiter plenty times on dyno & no contact yet.
if michael refering to .3mm thats about .012 inch. if u do a cnc valve job and valve unshrouding in the combustion chamber, takes about that to bring chamber back to stk. cc. i've decked ten heads as much as .025-.032 inch on stk piston bikes. good build skills on that measured tight piston to head, major factor in making big hp/torque.
Discussion Starter · #12 ·
The Woosner pistons are just absolute PORN to work with just look at em.:x
1 - 12 of 12 Posts
