1 - 2 of 2 Posts
I have the stock exhaust back on and the butterfly cables are not installed do I need to reinstall them. The question is with the cables off is the butterfly valve full open or closed thanks
I believe its full open. If yuo look into the inlet (bike side) before installing the valve is visible. Ill check at home later, but im fairly sure. That would make sense, just in case of a failure in the system I would think it would lock open, but Ive been wrong before.
(dont repeat that)
1 - 2 of 2 Posts
