1 - 3 of 3 Posts
Dose anyone know if the 2008 or 2009 ZX10r front forks will fit on a 2004 ZX10r and will you be able to use the 2004 front wheel and axle? Or do you have to use the 2008 or 2009 front wheel and axle?
La Flama Blanca
You will need a 06-09 wheel, a 08-09 axle, a 08-09 fender, and (depending on brake calipers/rotors) spacers for your calipers. The 08-09 forks are also longer than the 04-05 forks so you will need to drop them in your triples a good bit.
1 - 3 of 3 Posts
