1 - 11 of 11 Posts
A plea for help! :notworthy:
Hello All
I scanned through the forums to see if I could find anything and came up empty. My bike is throwing the 46 code for the fuel pump relay stuck on. I replaced the fuel pump relay though and it still gives me the same code, and I can hear the fuel pump never shuts off.
Any advice on what I need to do next? I don't post much but I look to you all for all my technical issues and have never been steered wrong. Any help would be appreciated. Thanks in advance.
no1speshal
2007 ZX10R Special Edition
Thanks Siwa. I hadn't thought the ECU would need to be cleared. I kind of thought it would do that on its own! I will see what I can find out about clearing codes and report back. Thanks again for the help!
no1speshal
Well, the ECU will clear the code itself when the issue is corrected. There's no way to manually clear the fault in the ECU. So I think you still have the issue.
How did you replace the relay? The fuel pump relay is inside the relay box. It's not a separate piece. So did you replace the entire box?
Hi SkyDork. Yes, I replaced the entire box. Is it common for these to go bad? Maybe I just got a bad one straight off the bat. I am jonsin' to ride again so any and all help is appreciated. Thanks for chiming in!
no1speshal
no1speshal
No, they're not prone to failure. Especially if you put a new relay box on there and not a used one.
Have you checked the circuit according to the manual? It may be a grounding issue to the pump that is causing it to run an bypassing the relay all together. Gonna take some investigation with a meter. It may be the ECU that's faulty also, but not likely.
Discussion Starter #8
FML - Losing battle
Thank you SkyDork
I have new, but similar, issues as before now.
Here's the Update:
So, I had to put my bike in storage while I sold my house and bought another one. I finally took my bike out of storage and decided to take it to a shop. Something I have never done before, and ultimately a big mistake because I chose the wrong shop. The damage that shop has done to my bike is outrageous. When the [email protected]$$ at that shop found out I did not want them to fix my bike and that I was coming to pick up my bike, he literally ripped a handful of wires, about 10 from the three plugs feeding the fuel pump relay box, ripped out the fuse box, broke the mirrors, ripped the instrument cluster out, along with a handful of some other crap.
So far to the tune of around $2500. Yeah. Law suits filed and everything. Now I am back to trying to fix it myself again.
Now that I am back to the fuel pump relay, does anyone have a picture of the wire colors and which plugs they go into on the connectors? I have bought new connectors from Kawasaki, and new pins to terminate the wires. Although I can read a schematic, the schematics in the repair manual do not have a good depiction of 'where' each wire is in its respective plug. I am close, but I need a few more wires to be terminated before I can add the battery. Anything as simple as a picture of the plugs in place with the wire colors visible. Or, a schematic that has the wires and which plug, and location, they go. Honestly, at this point, anything would be a tremendous help.
What's in it for you? MONEY!!! :dollarbill: (I swear to god I will pay you - I'm sick of my bike being dead!)
I will send $20 via PayPal to anyone that will send me pictures that show what wire goes into what pin on each connector.
I will send $100 via PayPal to anyone that can help me successfully diagnose why the fuel pump would not shut off, as I expect once I get the wiring back in order, the same issue as before will return.
Thank you SkyDork
Here's the Update:
Well, isn't he a pisser. :puter::eek::eyecrazy:
I don't have my G2 any longer, so no pics from me. But I do still have the wiring diagram! Do you have the service manual? That's invaluable!
Discussion Starter #10
Thank you SkyDork
Here's the Update:
Well, isn't he a pisser. <a href="http://Zx-10r.net/forum/images/smilies/smilies/puter.gif" border="0" alt="" title="puter" >:)</a><a href="http://Zx-10r.net/forum/images/smilies/smilies/icon_eek.gif" border="0" alt="" title="Eek" >:)</a><a href="http://Zx-10r.net/forum/images/smilies/smilies/eyecrazy.gif" border="0" alt="" title="Eyecrazy" >:)</a>
I have the wiring diagram but it doesn't show the pin number and wire color in the same diagram. Thanks, though. Someone sent me a text, I may have it sorted! Hooray! Thanks!
no1speshal
having same issue
So how did u fix issue? my bike isthrowing a 46 code this is the 3rd time it was just a skint wire once the 2nd time i couldn't tell u but I went through harness and tapped everything thatit could possibly be? please help I was selling it both times! just attempts to crank this time it ran for a while and when I cut off it never would crank again.!~
1 - 11 of 11 Posts
