Status
Not open for further replies.
1 - 20 of 25 Posts
Gen2 Ripper
My back just can't take it anymore and another surgery is happening over winter. So selling bike now while riding season is on. I am located in Northern delaware. Very close to PA(30 minutes to Philly up 95). Blatimore MD is about 1.5 hrs away. Jersey is also only less than an hour.
I added videos that can be viewed on the second page so check them out after you read all the questions/responses.
Title in hand! I am original owner. 12,706 miles . Bike has never ever been down in any way. Very well cared for by an anal owner.
Bike DOES NOT BURN OR LEAK any kind of oil. Fork seals DO NOT LEAK. NO weird noises of any kind! READY TO RIDE AND ENJOY!!
This is a STREET bike with some go fast parts. But very, very trouble free setup.
Modifications are as follows-(I will not part out, new owner can sell what he doesn't want)
Never in rain and never washed with a hose. Only hand detailed with Meguiars quick detailer, micro fiber towels, and bug/tar remover for really dirty spots like under tail section. I do wax all painted surfaces and it shows. Paint, the green and frame's metal flake POP in the sunlight. Even the rims get waxed so brake dust won't stick. I'm anal!!
The mods are....
16T Driven front sprocket, 45T rear SuperSprox Stealth sprocket and DID ZVMX gold chain=800 miles on setup.
2010 10R front calipers, Russel steel brake lines(F/R), Vesrah RJL pads, EBC XC front light weight rotors=800 miles
Ballistic EVO2 light weight battery(weighs 1.5lbs)+balance charger=5 months old
Healtech speedo healer V4
Healtech GiPro gear indicator(red display)
PowerCommander3 USB w/all discs and instructions+9v connector= Map is custom dyno tuned
DynoJet multi function hub+ disc and all instructions
DJ clip on mounted map selector switch
Piper Cross Race air filter(just cleaned/re oiled)
Secondary throttle plates removed
Competition Werkes GP pipe.
Delkevic cat eliminator mid pipe(I have the stock catted mid pipe if you want it quieter)
CarbonFiber ram air duct covers next to tank.
ZeroGravity light smoke CORSA windscreen(I have stock screen in decent shape)
Frame plugs to hide factory holes.
A&R Low Beam HID kit 6k, High Beam bulb is a 6k standard(light blue) Has Relay wiring harness so functions perfectly(option I paid more for)
LED front running lights(match HID color perfectly=6k)
Sato gold Rearsets
Pazzo gold shorty clutch/brake levers
Billet brushed aluminum adjustable kick stand(can be used if returned to stock height too)-very light
Ohlins steering damper rebuilt to Race Spec by Lako Performance Group= TRUE race spec internals
TWM carbon fiber quick release gas cap(threadless)(comes with stock keyed gas cap in case buyer wants keyed cap)
Kawasaki solo seat cowl(no passenger seat or pegs anymore)
1/5th quick turn throttle insert
Fresh spark plugs last week(just changed after over 12k miles and look great/still have in box)
Now, this next stuff someone can leave on and enjoy like me or remove and sell to make some money back if they aren't into it. Everything I am going to list comes right off and I know is not for everyone...completely reversible.
Myrtle West swing arm bolt on extensions. Bike sits at 62.5" wb.
MPS Spider dry 30 shot nitrous kit(sneaky Pete kit) with 10 oz bottle hidden in tail section. Along with NOS mini 2-stage progressive controller. Fully tuned and multi hub stores the secondary map via bar mounted map switch. Tuned VERY conservatively. Stock plugs I just removed after over 12k miles shows this.
Orient Express tether kill switch with rocker switch(not using switch so great for the fan mod if you want the fan switch mod, there's the switch. Tether is hooked up)
Bike runs perfectly. NOS map is a richer tune by a great tuner=Greg from HyperBike out of Baltimore,MD did the kit and tune.
You don't have to use the system and easily comes out and same for the extensions. So if somebody wants to knee drag its literally a 3 hour job to go back to road race style.
Bike is lowered 1.5" F/R and I have the stock dog bones to raise it back up.
All that stuff is easily reversible. When you look at bike you can not tell it has a NOS kit hidden and that is what I wanted so I could surprise the newer, bigger, and faster bikes.
F/R tires are Shinko Stealth 003 U-soft tires and are at the wear bars. Tires are only thing bike would need soon but not immediately. This bike eats tires and I chose sticky, safe tires over longevity.
I also have pig spotter LED mirrors on bike wired to turn signals.
But I have stock mirrors, stock clutch/brake levers and stock rear fender as I do have an undertail fender eliminator too w/LED lights(white lights). I also have the stock heavy battery sitting on a tender too which is perfectly fine and holds a charge.
Bike is ready to ride with no surprises, no hack job on anything, anywhere. I replaced the original stator at exactly 10k miles, it burned up on me which is common on these bikes. This new one is perfect as I looked at it 3 weeks ago before a long trip.
There is honestly NOTHING on this bike that is not legit and solid.
Can ride it home 500 miles easily if needed. Or more.
All the green bodywork is like new and original with NO dents or scratches. I removed the "Ninja" and "zx10R" stickers day I bought the bike. Only scratches are on very bottom of belly fairing because of my driveway getting in/out. can't be seen unless up on stands.
I will include the F/R stands and bike has rear spools on it.
Looking for $5500.
I will not part out or remove any parts. I'm not gonna change stuff in a hurry. New owner can remove whatever he doesn't want and make some cash back but that's up to him.
Here are CURRENT pictures as it rides today.
Gen2 Ripper
Damn man sorry to hear. GLWS and good luck with your surgery.
Thanks man. Been toughing it out but can't anymore. I really had to decide whether to keep taking pain meds and deal with it to be able to ride. Or stop riding, have the surgery and not take pain meds anymore. Well, my recent MRI showed I am doing more and more damage(crushed discs=all black MRI image) and if I keep it up I may loose more than just the ability to ride a bike. Doctor pretty much scared the shit out of me telling me how much worse I am making it by doing what I am doing and putting off the surgery. Been having my arm go numb riding and right leg spasm on me REALLY bad to point I have to pull over and hop off bike in traffic.
SO, Here's a great running bike that is fast, safe, and has the potential to be whatever somebody wants it to be. Knee drag or street/strip occassionally.
I ride the bike in the twisties as it sits and it still leans/turns well. Knee draggers would want to raise it up and take off extensions and I have ALL the parts to do so easily.
It really is a GREAT running bike. And immaculate in appearance.
Very clean bike man. I hate that you have to sell it. Good Luck with your back problems man. I have a cervical spinal fusion between my C6 and C7 vertebrae and luckily, I am still good to go.
Gen2 Ripper
Thanks. I rode it yesterday for just over an hour and am hurting pretty good today.
Somebody buy this bike and you will make out like a bandit.
It's prime riding season and this bike is READY TO RIDE!!
Gen2 Ripper
I only use Mobil1 Racing 4T 10W 40 bike oil and change it every 1200 miles MAX, never go over 1200 miles before changing oil and filter. I recently switched to K&N oil filters 3 oil changes ago. Before that I only used genuine Kawasaki oil filters but the nut on the K&N filters makes changes so much easier.
Oil in bike now has 820 miles on it. Did the oil when I did the front brake setup, pads, and battery before spring time.
Lotta bike for the $$. GLWS. Sorry bout the surgery. Just had a shoulder reconstructed a couple months ago and havent ridden all season.
Gen2 Ripper
Discussion Starter #8
Thank you. I am a little flexible on price too so anybody that is a ways away its still a good deal for them.
This bike is READY TO RIDE. Make me an offer close to my asking price guys.
Gen2 Ripper
Getting a couple nibbles....Great bike for a Great price.
BigCat for Prez!
Damn Eric sorry to hear abt this. U think possibly down the road after ur surgery ud be able to safely ride again? Id hope so buddy. this is off topic, but if at all possible could u send me ur street map? Id like to see what it will do in my bike
Gen2 Ripper
Discussion Starter #12
I'd love too but I don't know how. My tuners always did all the PC3 stuff. I don't even know how to up/download a map onto it,lol.
Gen2 Ripper
Discussion Starter #13
BigCat for Prez!
ah ok, its cool buddy
Gen2 Ripper
Discussion Starter #15 (Edited)
Here's a video describing the nitrous kit. I will be adding more videos later today after I wake up. I actually just fell asleep waiting for this video to upload to you tube.
Enjoy the hidden nitrous explanation(I am boring I know).
Neverending, open your PowerCommander program on your laptop and connect the USB to your PC. 9V to power it or turn the bike on so the PCIII has power. 3rd set of buttons on the software on the left, click "GET MAP" and that will pull up the map on your PCIII. From there, you can click "SAVE MAP" on the first set of buttons. Save it wherever youre gonna be able to find later. From there, you just attach to an email.
Gen2 Ripper
Discussion Starter #17
OK, I'll give it a try later today.
Hey, is the sound working on the video I embedded? First it was, then second time I viewed it here on the site the sound was dead.
LMK please.
Sound is good on my end.
Gen2 Ripper
Discussion Starter #19
Here's a video I sent to a guy who is interested in the bike. I had just woken up and took this video of bike being started and running.
I am a lame commentator when half a sleep,lol. Enjoy
1 - 20 of 25 Posts
Status
