1 - 2 of 2 Posts
Full Gallery of Pix here: https://1drv.ms/f/s!AvOao1F5QbC5g5BGJEzSN8uLzYe_jQ
Selling my 2007 Ducati 1098 track bike with clean title located in zip 17972 with 7439 miles. Do NOT have street fairings and accessories or kickstand but all original wiring is intact if a conversion is desired. It is a track bike and has been down twice but at very low speeds. All damage is Superficial. Only issue is cold starting. Just needs a some intermittent throttle inputs for a few minutes until it gets warmed up. Then it starts perfect every time. Selling because I bought a new motorcycle.
$8200
Email will probably be the quickest way to get a hold of me: [email protected]
*Engine rebuild by Ducati Winchester (DucPond) including Pistal Pistons + ARP hardware. Making over 150HP at the wheel on pump gas.
*-1 front sprocket (stock rear)
*Full Oversized Termignoni Exhaust
*Ohlins 25mm Fork Cartridge kit - 225 lb rider
*Ohlins TTX36 shock - 225 lb Rider
*Brembo RCS19 Brake Master Cylinder
*Factory Pro Ceramic Shift Kit + Lightweight Centering Spring
*Motion Pro Quick Turn + Cams
*Nemesis Traction Control (over $2500 + will include All Tire Maps, USB adapter and Software)
*Oberon Clutch Slave Cylinder
*Woodcraft Vented Clutch Cover
*Woodcraft Clip Ons
*WoodCraft Rear Sets
*Dynojet Quickshifter (Settings controlled through Nemesis WinTC Software)
*Water Pump Slider
*Under Body Sliders
*Sato Ride Height Adjuster
*Forsaken Motorsports Shock Rocker
*Ducshop Microtec ECU (includes USB Adapter + Software)
*Full Spectrum Pulse Li-Ion battery + upgraded wiring. Includes Full Spectrum Charger plus balance charger.
*YoYoDyne Slipper Clutch
*YoYoDyne Lightened Flywheel
*Brembo T-Drive Rotors
*New Vesra RJL-SS Brake Pads
*Ohlins aftermarket Steering Damper
*Podium Adjustable offset Triple Clamps
*2 Full Sets of Armour Bodies with oversized intake runners (Not pictured is additional front fender)
*Full Set Spare Wheels with Q3 tires + built in additional front pickup for Nemesis TC
I also include the rear stand shown, 2 spare front fairing stays, 2 oil filters, and all other spare parts that I have.
I will also include a fully functional track only (mostly stock) 2005 Suzuki GSXR600 [no Title] with 30k miles with this Ducati FOR FREE. Why? I built it for my Ex-GF and don't want it around anymore.
1 - 2 of 2 Posts
