Hi guys i have a 2006 zx10 motor in my pulling tractor and it has worked great for 4 years but last summer it started "clicking" when i hit the starter button. it seemed to get worse over the summer sometimes have to press the starter button 20+ times before starting. So this spring i have checked all grounds and all connections. I put a volt meter on the side of the starter solenoid that goes to the starter. everything seems to be fine. when i press the switch the voltage would show after the solenoid. I took the two bolts off the back of the starter and filed between the starter and the block.
All this and still no luck. has anyone seen this problem before? attached is the video!
( the clicking noise is the solenoid)
https://plus.google.com/u/0/1006025...6146272439364603570&oid=100602521145665586509
