1 - 20 of 25 Posts
Still here
Dry weight To Be Determined those teases.
Still here
higher compresion, revised rake and trail
.4" shorter wheelbase. Seats a little lower.
Same dumb damper, wonder how light they've gotten it?
Still here
2006:
Bore and Stroke: 75mm x 56.5mm
Compression Ratio: 12.2:1
Wheelbase: 55.2 inches
Rake (Caster Angle): 23.45¡
Trail: 100mm (3.9 inches)
Seat Height: 32.3 inches
Dry Weight: TBD
2004:
Compression Ratio: 11.9:1
Wheelbase 55.6 inches
Rake (Caster Angle): 23.75o
Trail: 102mm (4.0 inches)
Seat Height: 32.5 inches
Dry Weight: 396 pounds
The compression ration went up .3 and the redline is up to 12,200.
The guys over at 1000RR.net are talking about a 5 hp gain. I don't know where they got that info. Also rumors of it losing 26 lbs.
Hillbillie Mod
26lbs??? :eyecrazy:
maybe it will only have a 1 gallon gas tank! :lol:
ps...I'm at work and can only post a quick reply from this computer. When I get home I'll insert the http://www.motorcyclenews.com/jpeg/314/6784613.jpeg[img]
Maybe this'll work?
Nope
Heys Mods...BD and Andy...or should I say Be Dandy.....if'n yer bored mebbe you could fix my last post so the pic'll come up? Sorry for the Be Dandy thing...
Hillbillie Mod
:lol:
after the time it took to type two new posts you could have edited your first! :crackup:
alas....stoopid work computer won't let me reply to posts, edit posts, or send pm's. I can only do the quick Reply.
someone should post a pic of the 1000rr in a rearview mirror because thats the only way we will recognize it on the street :zx_red: :zx_green:
1 - 20 of 25 Posts
