1 - 5 of 5 Posts
Hi Guys, can you please give me the stock settings for 2005 ZX-10R
Greatly appreciated.
Thanks
rear is 1 3/4 turns out from fully seated rebound damping force adjuster. and compression damping force adjuster is 3 turns out from fully seated. front isspring preload 0.6in. from top of adjuster rebound damping force adjuster is 9 clicks out from fully seated and compression damping force adjuster 7 clicks out from fully seated position. for 150 lb rider no passengers
by fully seated you mean hardest or dialed all the way in? Then to adjust to stock, turn clicks out? Cheers! :thumbsup:
Sorry to bump.
So basically:
Rear:
Rebound: 1 3/4 turns out from full stiff
Compression: 3 turns out from full stiff
Pre-Load: ????????????
Front
Preload: Rings? (0.6 inches) ???????????????
Rebound: 9 clicks out
Compression: 7 clicks out
Can someone please give me the one from the owner's manual?
Thanks
1 - 5 of 5 Posts
