1 - 5 of 5 Posts
Just ordered power commander and boz bros moria system.Wonderin if anyone has a map?
Newfie Bullet
Someone elses map for same pipe and bike may not do you much good...All depends on where ya live(as in sea level)condition of the engine...Even if he lives 2 doors down yer bike will differ from his in some lil way...More than likely it will be close but spend the coin have a map done specifically for yer bike..
POST YER DYNO RESULTS TOO...In sae format..
Run the Akro full exhaust map your bike will run great and fine. I put this exhaust on my 06 and the map barely needed tweek'n. I also put the same pipe on my friends 05 with the Akro map and his runs just as good.
Thanks for the help. There isnt a dyno here so i have to use a diff map until i have a chance to run it on the dyno.
1 - 5 of 5 Posts
