1 - 13 of 13 Posts
· Speed Freak
OK guys well I'm scrapping my zx12r project so parting her out. I'll add on the rest of the stuff like the chassis and such (mikuini rear sets and tripple, etc.)
PLEASE PM ME FOR PRICES OR EMAIL [email protected]
The head and cam combo has a sale pending but posting pics up here anyways. Muzzy cams, springs, retainers and gears.
stock crank (needs reconditioning)
Stroker crank 4.6mm stroke done by Marine Crankshafts in Cali (nitrite treated) This was a crank that was done by Falicon originally and then it was redone by marine crankshaft and has not been in a bike yet I have the space are well it is .100"
set of throttle bodies modifyed to fit the modern injectors, I have a set of 04-05 10 hole 330's as well but what are in them are 4 hole 440cc injectors. I have the stock 2000 injectors as well. I was intending to plumb a aeromotive FPR in line after the rail so I bought another inlet pipe and cut the TB bracket down to fit everything. I know its modded and not stock so idk if anyone wants these.
Muzzy big bore 1270 kit with coated pistons. Will need a ring set and piston clips. The pins I had cleaned up and set in a bag but they will need to be cleaned up again or you can buy new ones.
R&D Undercut transmission with Low 1st gear
Carbon fiber ram air duct covers (painted)
Billet clutch basket
· Speed Freak
Discussion Starter · #2 ·
Coils
Water pump/oil pump
Stator cover with GOOD stator
Stock oil pan in great shape, no holes or anything
Rotor/Charging
Crank Trigger
Oil cooler
Side cover
Starter
Clutch cover (has a rub spot from race fairings)
Crank rotor/trigger
Radiator (has NO leaks) still works great just has minor damage as seen on the front fins)
Inner basket, pressure plates and springs
Coolant over flow
Sprocket cover
I have a complete wiring harness with ECU and all sensors and Reg/rec.
PC3 USB
Ignition module
Muzzys Air shifter (considering keeping this)
Ohlins Tripple clicker Rear shock
Stock swingarm welded 4"s over
Frame with Clean title
Sub frame
Marvic Magnesium wheels F&R
Mikuini Rear sets
Mikuini Tripple tree
Gauges
Fairing stay
Race bodywork (uppers and lowers, tank cover and rear section and fender)
Fuel tank with or with out pump
Front forks
BREMBO brake system
gear position indicator
Battery box with a good battery
Scotts steering damper
handle bar controls
I'll get individual pics when I break down the chassis either today or tomm!
plus i forgot the air shifter if u do decide to sell it i'll snatch that quickly of your hands if you want and of course you kno everybodys gonna ask the price of that damper plus thanks for that nos kit u sold me a while back
· Speed Freak
Discussion Starter · #9 ·
was looking to get 400 for the air shift kit
damper is sold
I only have a front sprocket and it is 530 but forgot what size it is
make an offer for the frame :thumbsup:
· Speed Freak
Discussion Starter · #10 ·
Rear sets $315 shipped
Brembo Rotors $250 for the set They are slightly over 5mm thick. Min thick is 4.1mm
Brembo calipers and master cyl $250 plus shipping
Titanium Exhaust hanger – make offer
Power commander $150 Ign module $200
BMC filters – make offer
Airshifter $350 shipped
Mikuni Tripple clamp and clip on’s Bars not included
Ohlins Triple clicker $550 shipped
Gauge cluster I honestly don’t know the miles! But guaranteed to work
WEGO II Wideband 02 sensor
Full Akro SS system with Ti shorty pipe (02 sensor not included, I have the plug for pipe)
1 - 13 of 13 Posts
