1 - 6 of 6 Posts
I hope someone has the solution to my problem. I am working on a friends 2000 500R. I can get it started but it will not keep running, even with the chock on. It really kicks out the smoke when it does run with the trottle full on. It also shakes bad when it's running. I've taken the carb off, cleaned it out and put everything back together. I pulled the plugs and they look good. Any ideas of other things I should check before I take it to the dealer and pay the big bucks? I look forward to any help you can give me.
Smokin is running really rich.. shaking probably because it's only running on one cylinder.. replace the plugs and do over..
Probably not.. by now he should of taken it to the shop and spent the 85$ to get it fixed..
Actually I have one of my Air Force buds working on the carb. Thanks for continuing to check in on this. It is appreciated.
1 - 6 of 6 Posts
