1 - 15 of 15 Posts
i had no strap and the bike is stock exept yosh. slip on and my best run was a 10.73 2.00 6ft(i know its crap) i thought i was spinnin off the line the whole time and it was my clutch slipin i know it can do better so when i get a new clutch ill do better haha
Discussion Starter #2
got back to the track and got my time down to a 10.41 with a strap on the front and i know i can get better 10.41 1.78 60ft 134mph still runnin stock everything exept yosh slipon can anyone remeber their stock setup times
Mph seems low....what is your weight. Also where are you located
Those are excellent times for a person just starting to race. I think there are a lot of gaps you are not disclosing ie. lowering, gearing, swb/lwb, etc. More details about your bike.
post a little more info to help us out. when i first started on my 10 i was running 10.60's just a slip on, stock height, wheelbase, etc... get some more practice and youll watch those times drop fast. your mph seems low. i think i was trapping high 130's-low 140's with stock setup. get some runs in and learn that clutch. 9's on a lowered/strapped stock motorcycle is possible with practice. :thumbsup:
my bike set up as is yosh slip on and lowered 3"(forgot to mention in prevous post)and straped in the front and i am bout 170-175(unsuited) the rest is stock my slip reads
reaction-.5199(.5000 is perfect at this track marion county ohio m.c.i.r.)
60ft-1.76
330ft-4.64
[email protected]
1/8 et-6.84
1/8 mph-112
1/4 et-10.41
1/4 mph-134
i will eventually change gears,filter,add pc,myb stretch id like keep swb for as long as i can money is tight for me but i am open for advice and help on goin faster
seems like a good start. i would try a -1 front sprocket, theyre cheap and youll lower your gearing while adding a little bit of wheelbase in the stock arm. also, what RPM do you leave at?
i thought about just goin down 1 in the front for a while cause i didnt want to buy both front and rear 525 sprockets i didnt know if i should switch to a 530 setup on swb? i know i defenetly want to run a 530 when and if i stretch it
i run the stock 525 size but aftermarket sprockets. holds up just fine for me
Discussion Starter #11
what kind of sprockets steal or aluminum sunstar,votex,driven.afam ? i just seen alot of bikes runnin 530s and i figured myb they do for a reason but most r gsxr 1k's i had the only zx10r at the track
front is steel sunstar, rear is aluminum Vortex CAT5 with either an EK or RK o ring chain(im not 100% sure)
A 525 chain is plenty strong for a 10R, even if it is stretched. Only if its a stripped, grudge bike with a BIG motor and large shot would you need a 530 setup. Just run a quality chain like an EK ZZZ and you'll be fine.
Your MPH does seem low, what is the altitude at that track? I've ran 138mph (113 in 1/8th) on my bone stock 2008 and I'm over 300lbs in gear.
Squid wannabe
Got to a 10.4 @ 137 but that was a few weeks ago
this weekend i will be racing again on the 2 wheel speed in the 10.5 class... let you guys know how i do =]
Discussion Starter #15
im located in ohio(mcir is the track name) im not sure of the altitude it was 9:30pm when i made that pass proly 80+ degrees out i also made another pass 8:30pm
reaction-525
60ft-180
330-4.69
594 et-6.49
1/8 et-6.89
1/8 mph-112
1/4 et-10.48
1/4 mph-132
1 - 15 of 15 Posts
