First, a thank you in advance for any input here. I haven't been around long, but I frequent the site to educate myself on my 2004 & I do appreciate the perspective.
Long & the short: After my CR125, I've been on street bikes since I got my motorcycle license @15 years-old. Started out on a YSR-50 which is even funnier as I'm 6'1". I've had about 15 bikes since from every manufacturer. Team Green I've had two '03 ZX-6RR's, and I'm now on my 2004 ZX-10R. I had been off bikes for a decade as, on 12.14.2005, a 77 year-old lady was driving her car the wrong way down a one-way street which I realized after being run into after rounding a blind corner on a beautifully bright sunny day. I never thought it could happen. I could drag pegs on interstate entrance/exit ramps; I could do standup balance-points for miles; I could do 200' stoppies; I could always - for 15 years at that point - out accelerate, out brake, out maneuver any accident, but then it happened. Make a choice... lowside & go under the car, or highside & go flying. I chose the latter, flew 75', landed on my helmet, and ended up with a subarachnoid brain hemorrhage (+) that left me in a coma on a respirator for a week. Anyhow, I made it out alive, and got the itch again about a year ago.
So now here I am @41. I found a lightly beat up 1st Gen for sale, negotiated it for $2800, and committed to reviving her. Honestly, I've got her in pretty good shape. Replaced all broken plastic (not painted, yet); replaced a cracked ram air tube, replaced a headlight assembly (stock had 3 broken tabs), added a slip-on (it was open at the downpipe), replaced a leaking fuel tank, added a GPR damper, replaced front pads, flushed DOT4 through the front master, Engine Ice radiator flush, synthetic oil change, replaced clutch & torn clutch cable (had barnett style double plate system that was like pulling open pitbull jaws), and added blinkers (haven't got working, yet). I'm sure I'm forgetting something, but that's the gist of it.
After all this, she felt great - surprisingly great, but the brakes went from great to garbage in two rides. I accepted the front master is tired, and I started my research here. I have now committed to replacing the front master, first, before replacing the calipers once I can save up some money. Here in lies my question as I see the sticky on this topic was written in 2008 with the following as direct swaps:
* 2006/2007 OEM ZX-14 Nissin [Front] Calipers
* 2007 OEM ZX-6R Nissin [Front] Calipers
* Late model R1 [Front] Calipers
As it is now 2018 & I'd prefer to upgrade with fresher hardware if possible, here in lies my question. Does anyone here know, unequivocally, what the up-to-date (models & model years) direct swap hardware is? I've done my due diligence with the search feature here, but I'm surprised it doesn't really work that well. I see the ZX-14 front caliper reference, but I'm not sure how late a model I can now use in 2018. I see people talking about Brembo calipers off a GSXR-1000, but I can't pin down what years. Furthermore - on Gixxers, I've seen some Nissin but then some Brembo binders on stock Gixxers in eBay so that's confusing. I've read about late model R1 front master cylinders working, but I can't pin down what years. And just like the Zukes, I've seen stock binders that weren't Brembos on eBay. Furthermore, on the Zukes & Yami units, do the MC brake switch plugs retain connectivity to our Kawi's?
I sure am hoping someone here willing to share has the answers to the above questions. Hope even more you don't mind taking the time to answer me.
Either way, thanks again!
atriot:
