1 - 20 of 442 Posts
He bought this bike not know all the problems with it. Well he finally brought it to me, and this is going to be the thread of his bike. Alot of things are wrong with it. We hope to make this bike near perfect again. He needs alot of parts, so help him out if you guys can. I'm not making alot of money off this build because I love the 10's.
1st pick the spray bombed exhaust. Plans are to get it right.
Discussion Starter · #2 ·
The Yosh wasn't cut right, or built right.
Discussion Starter · #3 ·
Right side of frame cracked. Someone tried hiding this and quickly got worse.
Discussion Starter · #4 ·
Front, and right side. The prep work wasn't done right on the paint, and spray bombed. Again I'm not dogging on or10r, but showing the build process, and what people can looked for in a abused bike. Trust me this bike is going to be nice when done.
Discussion Starter · #5 ·
The other side of the frame.
Discussion Starter · #7 ·
This is what happens when the wrong bolt is put in the leg cover panel. After I removed the bolt it began leaking fuel everywhere. You can see epoxy inside of the bolt hole. Now he needs a tank. Nice huh?
Discussion Starter · #8 ·
The fender eliminator.... Wait to see the wiring.
Discussion Starter · #9 ·
The clutch switch is unplugged... Lever wear is major.
Discussion Starter · #11 ·
The front of the tank mount is cracked from the frame moving so much. Also one of the mount pieces are missing.
Discussion Starter · #12 ·
Again gas tank ruined because of the wrong bolt... Also the tank was repainted cheap. You can see how the gas just ate through the paint.
Discussion Starter · #13 ·
You can see how long the bolt is.
Discussion Starter · #14 ·
Don't ever use housing wiring products. Water and dirt get in these, they come loose, and eventually cause a short.
Discussion Starter · #15 ·
Do not do wiring like this!
Discussion Starter · #16 ·
He didn't tell me he had this...lol
Discussion Starter · #17 ·
He needs a programmer if anyone wants to hook him up.
Discussion Starter · #18 ·
At some point it had a programmer, but it was removed.
Discussion Starter · #19 ·
Discussion Starter · #20 ·
Look at the spray bomb. The rear spring was even painted. I plan on making it red again.
1 - 20 of 442 Posts
