1 - 5 of 5 Posts
its around 1 tooth up in the back or so. Bike will also turn in a little slower. speedometer will read a little higher than before
Newfie Bullet
I wouldnt worry about turn diff,i would how ever get a speedo healer cause you will rack up more miles that you are not actually rideing with smaller tire..
Drop a lil preload or drop forks in the tripples 3-5 mm or shim up the rear that same amount and it will be back to same as a 55...OOORRRRR save all the bs and get a 55 on back again..
1 - 5 of 5 Posts
