They recommended going up one to two steps in spring rate.What are the recommendations for the use of this link?
What kind of rear shock valving modification needs to be done to utilize the link?
I don't know if its essential, just that they recommended it to get the most out if it. I spoke with Eric Wood from Woodcraft as well and he states that he went up 50lbs on the spring with good results. I'll PM you right now.Ok I'm running an Ohlins for my 19' ZX10R. So the valving should be good, But you think a stronger spring may be needed?
