im about to hit 15,000 in the next week, any pointers on what i should do for maintenance?
:iamwithstim about to hit 15,000 in the next week, any pointers on what i should do for maintenance?
i bought the with 10,000 a couple months ago so im not sure what maintenance has been done, what kind of plugs should i be running and are they easy to get tohave you changed spark plugs oil and filter maybe antifreeze check brake pads clean or replace air filter check valves make sure to change spark plugs if you have not yet should have already at 8000 miles thats all i can think of right now
There is a how-to on this site and the maintenance manual explains how to do it as well. However, unless you have a shim kit it would be best to have a trusted shop do the valve check and adjustment if necessary. I did everything but the actual adjustment since I dont have the kit myself. I trailered my bike to my buddy who runs a local shop and he did the valve check but I didn't need anything so I just buttoned her back up.is valve adjustment something you can do yourself or is that a shop only job?
