1 - 20 of 30 Posts
Rent this space
I'll probably tear the motor down over the winter, anybody have the 1078 kit from JE ??
hopefully someone will chime in with valuable info about this cuz were 2.5yrs into the 10's and people are beginning to rack up high mileage and experiment with internal mods and with this being a 3mm bore / replate it would be good to know certain aspects about it like heat or most likely excessive heat due to the bore.
Personally i'd do the 1051 2mm over kit if i were keeping my 10. http://zxzone.com/pistons.html
Rent this space
I was hoping someone had some pics BD to show the distance between cylinders , one more thing, I havent really had a close look at the lube system yet, but are there places I can tap into to add an oil cooler??
we have done several 3mm kits in the zx10's and many in the gsxr 1000's...these packages are extremely reliable when you keep compression in check...give us a call if you have technical questions about the 3mil kits for the zx10...thanks!!
dwayne
dwayne
makes sense however as i mentioned heat becomes a factor as the bores become larger and the walls thinner so lets say comp is kept at 13:1 with a quality replate, parts massaged and proper assem is heat an issue or not??
CC just wondering but what kinda power are people puttin down w/ the basic 3mm over kits?
Its not just 3mm over. If you go that route, go w/ custom cut cams. Get your pc3usb tuned in. And then test it on the track. Then you will get real numbers.
ninja- dont want to sound like an asshole when i say this so dont take it the wrong way but im already aware of that. i was just wanting to get an idea of some base #'s if you know what i mean?!
with headwork and cams along with the 1078 kit you "with good tuning" see around the 200hp range on motor w/ race gas.
Speed Freak
around 190hp for the 2mm kit right?
I was thinkin of doing the 3mm kit a lil while back ago but I think a 2mm kit would be better for me espically since I treat my bike to floridas awesome summers......I ride my bike pretty much any time of the year since in winter it doesnt go below 50 or so.....
I'd love to have a 3mm though, those extra ponies will always come in handy but thats why I have the nitrous :-D
I always say if you drive your bike around town and get into stop and go traffic pretty often to go 2mm.. if you just ride out to the race spots or track go 3mm..
:+1: Either way, lots of power.
So which is a better kit, and why? Wiseco or JE?
And what's the difference b/w the "italic" and the regular lettering. I know one's Wise. and one's JE, but is that it?
And... wow... they're rating an '04-'05 10R, stock I believe, with a "measured" peak HP of 159, and a "claimed" peak at 184! What kinda 10 did they get???
:thumbsup: carpenter has dyno charts on their website i think. Big power f'sho.
The same one the mags got.
dunno really, its kinda like dunlop vs mich vs pirelli i suppose. me i'd opt for JE.
"winter" that don't give you much time to do that FAF. You know we don't really have a winter down here in Florida. J/K
Good luck with the rebuild. Can't wait to hear how it went.
1 - 20 of 30 Posts
