can you give a list of parts and tools- what size pipe? and maybe a little how to...i dont really understand how it works:dontknow:
I machined nylon for a custom fit for this one in the
pic.
The simple way with basic tools...
The 08 throttle tube measured right at 1 3/8".
Find a some PVC with that inside diameter
(give or take 1/8")
Cut the width to match throttle tube. bandsaw,
hacksaw, etc. and sand it to smooth rough edges
Cut enough of the PVC "ring" out to fit around
where the throttle cables connect to the throttle
tube. Taper the edges.
I used set screws to secure insert, but superglue
would probably work fine.
