1 - 8 of 8 Posts
Hi i've been a lurker on here for sometime now, picked up a 05 10r last season and just recently ordered some new tires for the upcoming season. my bike is -1, +2 520 conversion. and as you all know stock tire size on the 1st gen is 190/50. i did alot of researching and it seems like a good idea to up the profile up to 55, however i've read somewhere that going from 50 to 55 is equivalent to +1 in the rear? if this is the case i'll be +3 is this a big deal? how much will this affect my handling/speedo/chain wear? sorry if this has been covered before, but i cant seem to find any information at all on +3 rear.
thanks,
jimmy
^^No Bike Bum^^
im 16/44 with a 190/55 rear tire and i ride mine on the street and strip... my speedo is showing about 10mph fast
thanks,
jimmy
i dont think your going to tell that much of a difference between the two sizes. the bike will sit a lil higher in the rear with the taller stance tire tho.
Licensed Dist of HaterAde
The taller or shorter profile tire will only aid in how the bike initially turns into a corner, handles, and some say there's a difference in the size of the contact patch between the 2......I've never heard of the sidewall size coming out the the same as +1 or -1 tooth on the rear sprocket though?.
^^No Bike Bum^^
:+1:
and you would have to have a sharpe eye to tell a change in ride height when you step back and look at it
Gen2 Ripper
It would actually be like taking a tooth away from rear sprocket if going up to a 55 series from a 50. I did the oppisite on my gen2, 55 to a 50 series. It is noticable to me the shorter size..like a 55 series worn down to the belts is best way to describe the 50 compared to a 55. You goibg up to a 55 will give you better turn in slightly and depending on tire profile, slightly less center contact patch.
My speedo was off 3mph when I dropped down to 50 series at 80mph checked via gps before and after.
1 - 8 of 8 Posts
