thanks, will go check that nowJK, there should be an adjuster about 5 to 8" down the cable. Simply turn it out until you have only a couple MM. HTH. :thumbsup:
that seems to have helped it a little.JK, there should be an adjuster about 5 to 8" down the cable. Simply turn it out until you have only a couple MM. HTH. :thumbsup:
thanks will tryYou should be able to adjust all the slack out. The top throttle cable will need to be adjusted out (made longer). Retighten the locking nut.
I played with the adjustment. Didn't help much. I think maybe it's stretched out too much.did you fix it
:+1: I have 0 play :mrgreen:Also a 1/5th throttle insert will help a ton.
