1 - 2 of 2 Posts
I purchased my 09 zx10 with 500 miles on it. I was never told by the previous owner that it had a immobilizer on it...The problem that i'm running into is i tried to connect a race ecu using the subharness and my fuel pump doesn't turn on. I went through everything and couldn't figure it out... I connected
12v directly to fuel pump and the bike started up and ran fine... I found out now it has a immobilizer and that is whats causing the fuel pump not to turn on the fuel pump being that i'm trying to use a race ecu...Does anyone know how I can take of this immobilizer system off the bike? Do I just disconnect it or do I have to run resisters or something of the sort..I'm trying to avoid running a relay to make the fuel pump work.
1 - 2 of 2 Posts
