1 - 4 of 4 Posts
So my bike was in a accident and it ripped off the nose of the bike since then it wont start the bike cranks but theres no fuel or spark when you turn the key the pump dosent prime or anything ... I replaced the tip sensor and any fuses that were blown the cluster is to messed up to read but a shop let me use one and it said code 39 which is a ecu issue theres continuity from both ends of the ecu signal wire at the cluster and ecu. Should I replace the ecu or has anyone ever had a similar issue
thanks in advance
Check that the pins on the ecu wires are all plugged-in, making good contact with ecu when connected.
swap ecu with a friend that has the same bike, check if it works that way.
check your wires going to the injectors and immobilizer and make sure they're all working fine.
1 - 4 of 4 Posts
