1 - 12 of 12 Posts
hey just got back in from work today, bike ran fine this morning, idles fine, on pulling away it is down on power then bogs down at about 5krpm till it hits 6k then it cracks on as normal.
fuel pump is running fine as far as i can tell, no misfire or backfire etc any idea's ?
fuel filter ?
any idea's, first dry night in a long time and it lets me down :(
deppressed biker :(
Is the FI light coming on at all when it does this?
With out a FI light coming on it could be any number of things and a little harder to track down. I would be leaning to fuel filter, fuel pump, or maybe a loose connection somewhere.
bike is used daily, filled up fuel two days ago, bike is garaged at night or when not in use, it is parked outside when im at work but is for the most part protected from the weather/rain by the building.
fuel pump cycles as normal on turning ignition on and appears to be pumping away as normal when running
Could it be a possiblity that maybe the gas tank isn't venting properly and this is causing the issues?
knowing my luck it could any and all of the above lol
gotta get me some sleep now and ill get a fresh start in the morning :)
many thanks for your input gents :)
Discussion Starter #10
update
checked fuel for water/debris, all clear, checked fuel pump flow, all good again
edit: checked venting on tank, all good
was serviced a couple weeks back, but checked air filter etc, all good
however what i did notice yesterday morning was the throttle/cable assembly top screw was loose bottom one was working its way to being totaly loose, stripped/lubed cables, reassembled, then tested thoroughly for 2 hours before i started work :helmet:
all seems to be in working order, power delivery back to normal :mrgreen:
thanks for the help :cool:
stevie
Dont mess wit White Ninja
So basically it came down to be a loose throttle cable :lol:
Hey man, better that than anything!
1 - 12 of 12 Posts
