1 - 2 of 2 Posts
Hey guys, had a good look around for similar threads but no joy, my zx10r has developed a stutter that won't let it rev beyond 9-10k rpm at full throttle, it happens after around 45mins of riding, but yet will rev to the limiter in N. When I rode it again is was fine for a while then developed the problem again... Have heard talks about vibrating side stand switches but apparantly this has occurred on race bikes with the stand switch removed...:sad:
The sidestand is only a switch with Normally Open contacts. You can put a jumper wire on the harness side and bypass that.
I would recommend checking your ground wire cluster where it mounts to the frame. It could be loose.
1 - 2 of 2 Posts
