It looks like it's a plot of hp vs road speed. Probably dyno'd in different gears, which will shift the plot horizontally.Awesome!!! :+1:
Why does the RED run go almost a 1000rpm more than the others?
Indeed. The correction factor on the 175 run was 1.15. That's a huge correction factor. The number I would use would be the 5th gear pull with the less dramatic correction factors. I have a feeling the dyno operator might have been boosting the numbers a little bit because I have never seen a correction factor that high. :dontknow:Dyno runs done on different days, different temp, air pressure and different correction factors. :headshake
I think your dyno guy is playing games with you.hey guys i just got my bike dyno and got this numbers i got a k&n air filter and a jardine pipe no cat no sec flies pcIII on pump gas, what u guys think
