1 - 20 of 28 Posts
Here's the dilemma, Running a shinko -1 on the front and stock rear the thing has run [email protected] on the rev limiter in 4th ,so i changed to -1 front, -1 rear and it went [email protected] 145 top of 4th no rev limiter ,are you guys shifting to 5th? Tks Oh thats stock wheelbase.
Good question, read a few threads down I hit last weekend with a 1st Gen(9.96s @146.5mph) and before that thought I was limited to 145mph before the limiter but actually got almost 147mph and never hit the limiter. Remember a 1st gen has Higher Gearing edit lower gearing... so I would think or presume you may need a 5th gear change because a 3rd Gen seems to have higher gearing stock a 1st gen with a 100mph 1st gear is a must....... but really think you need to go aggressive at this point to make sure you HAVE to change to 5th gear. :idea::dontknow:
sorry Tony...forgot to mention if you didn't know already I was at -1/+1 from the stock 1st Gen 10R gearing and Never go into 5th gear or I will loose time and maybe MPH because I am close to redline just before the 1/4.
bloo
Discussion Starter · #4 · (Edited)
I guess I'll try the 40 on the back again tomorrow, It's not helping my 60, but I didn't really give it enough time, I broke two clutch plates the other night, so didn't really have enough seat time with it, all my passes are usually with -1 and stock 41, I'd love to run my 43, but then she's to wheelie happy(maybe with longer chain) See the problem is, the air is starting to get better here and that means that with the stock 41 she's gonna hit the limiter sooner so I'm thinking this will not help. :dontknow:
why would you care about your 60? :dontknow:...the 1/4 mile time is what counts as you know and it doesn't hurt to have a great top speed to boot....we have even a video on this site with sucky 60 but the 10R doing over 150mph and very low 9s(with some race gas and full system I believe)..... but you can do it.:wink::thumbsup:
60 ft time is directly related to your ET. mph is usually the same.
My comment was based on my mentor the Pro Star Champ Ruthless Racing and he said to watch the 330 the 60 is not as important....I believe him I have sucky 60ft but do alright in the 330. :wink:
IMO on a stocker the hardest thing to do is slip out the clutch perfectly without a wheelie. that would be reflected in the 60ft time. how do you have a bad 60 and make anything up in the 330? wow, how far are you slipping your clutch out?
I can't really answer that question as I am a weekend warrior meaning I try so many things to control the Wheelie but I noticed it's not my 60Ft that counts to get me in the 9s but stuff I do before the 1/8.....In fact I got to 121mph stock from the show room floor last weekend with just a slip-on and no PCIII but not a very good 60ft. I believe and seen many with bad 60 foots but what you do after the 60ft on a stock wheel base can make all the difference from my experience so far as well. :wink:
we may go out again this wed. my 60s are a poor 2.000 right now. still ran 138mph though.
that 60 has nothing to do with terminal speed.... my old zx9r 1999 got has high as 138mph with a bad 60ft. :wink:
A bad 60' is a bad 60', but your 330' times are determined not only by 60', but how fast you get the throttle wide open. You can cut your personal best 60' by .2 (two-tenths) but if your 330' is slower slow will your ET.
MPH is an indication of power, not 60'.
agree or at least from my experience my 60 usually has nothing to do with my top speed or 330. :thumbsup: It really depends how fast I go FULL throttle after controlling a wheelie or not what the time is going to be.:wink:
i agree thats what i meant in the earlier post. how are you running 9s on your bike, or has it been modded to run that?
Read the strip section I run fat weighing in at over 200lbs only geared, strapped and slip-on and NO PCIII. I have to be on my best performance racing against the bigger bikes and other guys but my old 5yr bike usually represents well even with my fat arse.:wink::lol: .....as far as my 9s it's my Mentor Ruthless Racing....Seat Time and then it happens. :thumbsup:
straps make a ton of difference. now it all makes sence.
I DON'T KNOW HOW MANY TIMES I HAVE TO SAY THIS BUT IF YOU GO TO A GUN FIGHT WITH A KNIFE THEN DON'T SHOW UP as I wouldn't show up to a Track Day with my bike lowered and no suspension adjustments. My previous post was with ALL bikes with a strap. :heyyou:
1 - 20 of 28 Posts
