1 - 6 of 6 Posts
Gen 5 Now!!
are the cylinders walls nikasil plated?? was wondering if i should hone them as ive read some posts about not doing anything to them because of the special coating. im gettin ready to start redoing an 08 motor that i picked up. gonna lighten the crank and put je pistons in plus some other goodies. figure i ask before i get to that poiint
Gen 5 Now!!
Discussion Starter #2
They are nikasil but you should be able to hone them. Send it to Millenium http://mt-llc.com/ around $560 i think... They did my 04 cases. I would not lighting the crank, the stock crank puts the power down more "efficiently" than the lightened one, but that's just me though :thumbsup: Keep us posted.
Gen 5 Now!!
break down
well started breaking down the motor today and stopped after spliting the cases. spoke with millennium and they said i could use the aluminum oxide 240flexhone to deglaze the cylinders. just a couple of strokes though. heres some pics so far.
crank
i would not lighten that crank, already lightened from o6-07, back close to 04-05 specs. tasos is right, lose too much inertia at start, between gears with this short stroke engine.
1 - 6 of 6 Posts
