1 - 9 of 9 Posts
So i'm just wondering has anybody put a .45 or.50 in an 08 ZX10, and if so can you run with 91 octane? tks
Speed Freak
I haven't heard anyone on here doing it yet but I'm sure you can run them no problem... I am running 13.5:1 pistons on high test. if you go from the stock 12.9:1 to say 13.3:1 you should be safe....
08 head gasket.
Ok tks, i'm hoping somebody with an 08 Chimes in as well. My pump gas here is only 91 i think you guys have 93.
Speed Freak
if you put in a thinner gasket and degree stock cams or put a 04-07 exhaust cam in on exh side im sure you can pick up a few more hp... hard to say since i havent been inside one yet but I'm sure a good 5+ easy.... very easy
Where are the cam gears available to degree the stock cams Garth? I was under the impression you couldn't do it with stock cam gears.
Speed Freak
no, you can, you unbolt the stock cam gears in their location and there's a slotted section you can move the bolts to.... you just have to mark the cams so you have your setting points when you install them...
Oh so they are slotted, that makes thing easier. any lift #s come to mind?
1 - 9 of 9 Posts
