1 - 8 of 8 Posts
· Banned
i have an 07 i want to put a full exhaust on a tre and pc3 if i install this with correct map do i need to do anything else to it such as valves ect?? thanks
only to squeak out a few extra hp do you need to port and polish, install beta valves.
when it's time to get the valves adjusted then look at a bigger cam, port and polish, titanium retainers, etc.
then get the pc3 re-mapped.
i found a ti-force on this very site for just $400. found a shop that has pc3's for $265.
gonna have the butterflies removed, possibly a +2 rear sprocket.
tsukigi is running a sale now on exhausts, thats what i'd get if i hadn't found the ti-force
Discussion Starter · #3 ·
thats what i have is the ti force full exhaust 400. shipped cant beat that im not sure what the butterflies are but what i meant was if i put the pc3 and exhaust on do i have to get anything adjusted for it to run right?
· Banned
on the dynojet site there's a map you download that's used specifically for the ti-force pipe. that should make it run right.
use the search feature here for details on the butterfly removal.
good luck dude:eek:ccasion1
1 - 8 of 8 Posts
